Engine bogging!!!
Old Jun 30, 2006 | 03:19 PM
ruddiger52's Avatar
Car: 1983 Trans Am
Engine: V8 305 Crossfire
Engine bogging!!!
Hey everyone,
I have an 83 trans am with a 305 crossfire injection. When I step on the gas a little harder than usual the engine bogs and almost stalls. It will usually catch and then be okay until I have to come to a stop and then accelerate. Weird thing is i just had a tune up done. I do need to replace the valve cover gaskets because they are leaking oil. Would this cause bogging?? The two problems seem to have occured at the same time.
Thanks for any help
Old Jun 30, 2006 | 04:00 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Fuel pump maybe check your fuel pump
Old Jun 30, 2006 | 07:32 PM
krumb's Avatar
Car: 92 RS 25th Anniv.
Have u ever changed your cat.conv. or had it checked
Old Jun 30, 2006 | 10:04 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
I got a friend with a crossfire injection. those are pretty sweet engines. They tried getting the corvettes in 83 to use them but the had too many electrical problems, maybe you should check loose vacuum hoses, and maybe the control module is fired. If yo gave it a tune up, did you change the filter. maybe the vacuum hose the connects to the flaps on the hood is disconnected? I dont know, nevermind.
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Logan Bryant
Aug 27, 2015 11:52 AM
Out-Cast
Aug 17, 2015 10:57 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
