throttle cable sticking
Old Jun 30, 2006 | 09:34 PM
RArnold's Avatar
Car: 1984 Camaro conv
Engine: 350, .040, warmed up
I'm having problems with my throttle cable sticking, throttle ot returning to idle position.....I have a Weiand manifold which seems to place the cable bracket higher than the stock location, anr I'm thinking thats causing the binding of the cable........anyone else have this problem ?? any ideas or former posts to look at ?????
Old Jun 30, 2006 | 09:55 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Sticking throttle cable is one of most deadly experiences. It happen to me, after spraying the throttle valves with carb cleaner. man. I was at a stop, and I punched it full throttle and it went still 24 mph where I let off, but before i knew it I was 65 mph in a 25 zone. I hit it in neutral, redlined the engine, turned the engine off, and slammed the 4 disc brakes. Boy i took it home and rebuilt the throttle body. lubed the cable with graphite. crazy
Old Jul 1, 2006 | 06:35 PM
87gtaJOLENE's Avatar
Car: 1987 gta T/A
Engine: 5.0 TPI
Axle/Gears: 3:23
man what a story. My pedal started to become hard when i press it sometimes and I thought tehre was something wrong with the engine. Then I relaized it also happens when the car is off. should i grease up the line?? how do you do it???
Old Jul 3, 2006 | 12:44 AM
Honestly, If wasnt so cheap, I'd replace it. But I cant drive for another 8 months anyways, damn speeding tickets on open range. loving the desert in cali. But yeah, i'd replace it with good quality cable with teflon coated internally.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Randomtask2
Sep 7, 2015 05:06 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
