What is the function of this wire??
Old Jul 1, 2006 | 12:40 PM
smt91278's Avatar
I put new intake manifold gaskets on my 89 IROC. While re-assembling the upper intake, I notice I lost a wire. This wire plugs into the bottom of the plenum (towards the back) and runs back to the firewall. Once it hits the firewall, it plugs into the wiring harness. In total, the wire is probably 6 inches long. It also seems that its some type of sensor. What does this wire do? Where can i get another?
Old Jul 1, 2006 | 12:42 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
could be some sort of intake manifold air temperature
or something to measure the air temperature.
Old Jul 2, 2006 | 04:17 PM
Pat Hall's Avatar
It sounds like that's the exact wire you're describing. If so, it's for the IAT sensor, or intake air temp. You could probably buy a new pigtail one to splice in from most parts stores, or there's always the junkyards. TBI cars are all over in most yards, and they use the same wire and plug for the coolant temp sensor on the intake manifold. In fact, the last time I bought a coolant temp sensor, it came with a new pigtail and plug.
colton_carlson
Mar 8, 2019 12:21 PM
jklein337
Sep 19, 2018 06:23 PM
Out-Cast
Sep 3, 2015 09:05 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Bull86
Aug 10, 2015 05:43 PM
