change brake fluid?
Old Jul 1, 2006 | 12:54 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
change brake fluid?
I bought a little vacuum pump
and Im going to siphon my brake fluids.
i think for now all i wanna do now is vacuum most of the fluids
out of the reservoir and fill it in,
so it wont be a 100% flush.
my question is whats the possibility i hurt my master cylinder?
caz I heard lot of time u change brake fluids u could brake them..
any tip is appreciated
Old Jul 1, 2006 | 01:07 PM
TymeStopper's Avatar
Car: 2 Stangs, 2 Third Gens, AWD Talon
Engine: 302, 302, 305, was 327, 4G63
Transmission: T5, C4, T5, T5, 5 Speed
Axle/Gears: All Kinds.
I don't think it should hurt the master cyl. any. I do brake flushes at work all the time and never had a problem with that. But I've never done one on a 3rd gen, so it might be a lot different. LoL
Old Jul 1, 2006 | 01:11 PM
Vader's Avatar
It's usually a good idea about every five years or so. The old fluid can become contaminated with dirt, water, and debris from the system. I'd be surprised if you caused any problems unless something went very wrong with the process.
Old Jul 1, 2006 | 01:27 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
As long as you NEVER let the MC go dry you will be allright.
Old Jul 1, 2006 | 01:58 PM
sogabe's Avatar
Engine: 3.1L
cool, ofcourse i wont dry it.
just incased im going to leave a little fluids on the very buttom
of m/c and put new one in, so it'll be a little mixed with new dot3 and old dot3,
that shouldnt be a problem either right?
thanks again!
Old Jul 1, 2006 | 02:13 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Just keep the MC full as much as you can, all the old fluid will leave the MC as you bleed it.
maroe624
Apr 16, 2017 08:29 AM
z28_AJ
Aug 27, 2015 08:59 PM
Thornburg
Aug 25, 2015 01:46 AM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
