any thoughts on this chatter mystery?
Old Jul 3, 2006 | 07:03 AM
dennisgramm's Avatar
Car: 1983 Camaro Z28
Engine: 5.0L HO
Transmission: 5speed
Hi, about 6k miles ago had a new lutz clutch put in by a trans shop here, because of bad chatter in 1st gear...it continued, so they replaced it with another, and told me they did what was needed to the flywheel.( which was probably not what they should have done), the clutch works fine, no problems except that it has some chatter in 1st only. I have compensated for it by giving it just enough gas as I let clutch out, and sometimes it is fine, other times some chatter. It is not near as bad as it was before the clutch job, but is annyoying. I talked to two good mechanics, and they both said dollar wise just to live with it, till it gets bad, then they would do the job right. Here is my question.. how much just to replace flywheel with a new one only?, or do you have to replace whole clutch assembly so it matches perfect?, I am assuming like most, that if you have to pay for dropping the unit, might as well bite the bullet and do it all...but my clutch only has 4k milels on it. Are there any other options to correct this small chatter problem... a big burn out???....I do not hot rod my car and have never done a burn out...but am assuming that it would not work, but maybe make it worse.
Here is one more question...is it possible that something else could cause it???, I checked no leaks from the engine on clutch, and as far as we could tell, all mounts were tight. The trans seems in good shape, car only has 69k original miles on it....could the drive shaft/universal joints or even the rear problems cause this to happen? I noticed that someone before me had replaced the rear end from a wrecking yard, do not know why?
The car is a 1983 Camaro z28 5.0 H.O. 5spd. Appreciate any responses to:
dennisgramm@verizon.net
thanks much,
Dennis
___________
Old Jul 3, 2006 | 11:35 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
they probably machined your flywheel, when they "did what was needed". That should have solved the problem.
A new flywheel is around $80? Call up an auto parts store and check that one.
1st gear only, makes me think it's an internal transmission problem...
Elephantismo
Feb 13, 2019 12:51 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
camarohelp
Sep 12, 2015 05:45 PM
IROCZ1989
Sep 4, 2015 11:54 AM
