1 more plug wire question??
Old Jul 3, 2006 | 12:15 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
will these wires fit/work good with slp headers??? Thanks
MSD 8.5mm Super Conductor Spark Plug Wire Sets: MSD-31243 - summitracing.com
Old Jul 3, 2006 | 12:57 PM
RArnold's Avatar
Car: 1984 Camaro conv
Engine: 350, .040, warmed up
I have the same question --- the plug wires I got a while back, before the rebuild and adding headers are extra long for some reason, and I have wires hanging allover the place....I could put plug wire supports on the fenderwells and run them all the way over from there........who knows of a plug wire set that fits a sb chevy nicely without any extra wire laying around?? would a set with all 90 degree plug ends work better with headers ( my set has some straight and some 90 and I'm getting burned wires from the long straight ends)....and any suggestions on which plug wire supports to use with the tall Edelbrock v/covers ???? my engine bay needs to be cleaned up........
Old Jul 3, 2006 | 01:35 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
yea 90 degree boots are almost a must with headers..........
Old Jul 3, 2006 | 01:44 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I would personally buy cut to fit wires, so you can make them the actual length you need.
Old Jul 3, 2006 | 02:01 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
This has to be one of the best ideas I have seen.
https://www.thirdgen.org/forums/exha...lug-wires.html
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Derick15
Sep 17, 2016 05:28 PM
