PUSH ROD LENGTH ?
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
PUSH ROD LENGTH ?
ok went to install new 1.6 roller rockers on heads and decided to check geometry by using the marker on the top of the valve stem. well my witness mark ended up towards the outside of the head.(pushrod too long). used a pushrod checker and seem to need one 7.1 in. stock is 7.2 on a hydraulic roller i think? well cant seem to find pushrods any where in this length they seem to only have them longer for some reason. any ideas ? am i doing this right?
thanks
happy forth to all !
mike
thanks
mike
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Comp cams lists a 7.100 pushrod. Part number 7938-16
JEGS High Performance
Set of 16 for $141.99 or
Buy them for $12.99 each
Did the same procedure.
Just some info, my engine was a complete rebuild, heads rebuilt with 30' valve seats ( which sunk the intake valve a hair,) shaved .006", block shaved to 9.015".
Used 1.6 roller tip rockers, checked pushrod length and ended up with 7.050" length for the exhaust valves and 6.950 length for the intake valve. I ordered Manley pushrods through Scoggin Dickey, they were either $8 or $9 each.
They had to be sent directly from Manley and it took about 3 weeks.
Rob
Rob
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Originally Posted by Stephen 87 IROC
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I paid 150 to have crane make me some. I went through the same procedure and needed 7.625" all the way around and had to have the custom made. now they sit perfectly in the middle of the valve stem tip.
Car: 86 CAMARO
found the trickflows from summitt online, 7.1" for $90.00 all is good. now im looking for valve covers to fit over my roller rockers. theres a pretty crappy selection out there for tall center bolt covers.
RedLeader289
May 28, 2019 01:47 PM
skinny z
Oct 5, 2015 06:23 PM
