what would cause this noise?
Old Jul 4, 2006 | 02:37 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
When going down the road generally starting around 40 or so MPH there is a loud vibration/hum coming from what i think is the drivers side front tire. the faster i go the louder it gets. Also i can push the clutch in and take the car out of gear the sound is still there. Im pretty sure its coming from around the tire because if i would like shift ihard into the right lane on the highway the sound lessens untill i straighten back up. Could be because im taking weight off the tire.
Maybe the wheel bearings?
And thoughts suggestions are greatly apreciated
thanks.
Old Jul 4, 2006 | 03:12 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Yea, sounds like it could possibly be a wheel bearing. Get it in the air and see if you can move the wheel. Grab the top and bottom of the wheel and see if you can move it in and out .. if so .. wheel bearing.
Old Jul 4, 2006 | 04:09 PM
CamaroJosh1000's Avatar
Car: 88' Chevy. Camaro Iroc-Z
Transmission: Manual 5-speed
I agree sounds like wheel bearing.
Old Jul 4, 2006 | 04:49 PM
start'er up's Avatar
Car: 1988 pontiac trans am
yup, my uncle had the same problem in his iroc, if thats it, its nothing major
Old Jul 4, 2006 | 05:11 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
wheel bearing or maybe the tire is unbalanced? A new set of tires and a fresh balance can do WONDERS for vibrations.
Old Jul 4, 2006 | 06:20 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
New set of tires = $400
New wheel bearing = $10.
Start with the wheel bearing.
Old Jul 5, 2006 | 12:25 AM
BCdawg57's Avatar
well i just got new tires so i know thats not the problem. and yes the noise was there before the tires.
Thanks for the replies guys, ill check out that bearing!
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
