Starter engagement
Old Jul 4, 2006 | 09:31 PM
DracoZK's Avatar
Car: Z28
Engine: 350 L98
Starter engagement
Hello,
When I start my car it sounds as if the starter spins/engages too long. ie, the car starts but then there is this metal tyoe grinding type sound. A guy today said it was either the starter or the flywheel. Any ideas?
Is it possible to change the cranking length? etc etc...
Thanks,
Kyle
Old Jul 4, 2006 | 10:08 PM
Vader's Avatar
The amount of time the starter remains engaged is usually directly proportional to how long you hold the key in the START position. If the starter pinion or fork is binding or worn, the pinion may remain engaged longer than it should. It may be time to remove and inspect the starter.
Old Jul 4, 2006 | 10:38 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
If you were hearing that noise and the car wasnt starting then I would suspect the starter or flywheel... seems to me you just have an iffy starter, Starters are relativey cheap for our cars and some have lifetime warranties.
Old Jul 4, 2006 | 10:43 PM
DracoZK's Avatar
Car: Z28
Engine: 350 L98
Sorry let me mention that it is a LT1 starter due to having installed the t56.
But I will inspect it for sure. Would spacing/shiming it help in anyway?
Thanks,
Kyle
Old Jul 4, 2006 | 11:13 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
shimming the starter wont keep the starter from engaging longer than its suppose to. You probably have a solenoid thats starting to short
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
