hard start(detail inside)
Old Jul 5, 2006 | 03:11 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
91 RS v6. 3.1L auto
I put the key in ignition,
and crank the engine,
problem no.1:
it clicks and doesnt crank.
after couple try it cranks,
problem no.2:
it cranks for very long time,
here's some detail,
the oil pressure goes up first, to about 40,
then the voltage goes up to 13 before it starts up.
I have brand new battery, plug wires, cap&rotors, distributor, spark plug
and fuel pump and all new injectors, and new IAC valve.
I have a tiny exhaust leak on my right bank between the head and the ex-manifold, o2 sensor is old too. could these cause the hard start?
also my EGR looks old.
any thought is appreciated before i spend some money! thankyou
Old Jul 5, 2006 | 11:53 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
[quote=sogabe]91 RS v6. 3.1L auto
problem no.1:
problem no.2:
here's some detail,
Problem One...either bad connection at battery or starter..One thing I did to my ride was ditch the side post connections.Went to a top post set up..for the simple fact that my positive cable was a mile long,and the top post provides better clamping connection..and got the biggest CCA battery that will fit.Its also possible your starter solenoid is taken a crap..
Problem two...You either got a fuel/air/spark issue..Fuel pump relay sticking..air restriction...weak coil...hard to tell.Have to narrow it down.
Old Jul 6, 2006 | 01:32 AM
sogabe's Avatar
Engine: 3.1L
thanks for reply.
im guessing its the starter too, yes.
anyways PROBLEM AFTER ANOTHER PROBLEM...
my alternator died on me today.
i bought the car last year and never changed it, so
i donno how old it was, but the car would run with jumpstart.
but i park the car, maybe after 10min i get no voltage at all,
so this should be dead alternator draining battery right?
i was wondering, that would weak alternator possibly draing battery only little to a point where it cause the problem no.1 i stated above?(like it clicks, but no crank)
just wondering, thanks for any help in advance!
not to mention ur top post idea sounds really good.. i should try that
Old Jul 6, 2006 | 02:24 AM
jstrdn90rs's Avatar
not to mention ur top post idea sounds really good.. i should try that [/quote]
If your car ran with a jump start then the alternator would be okay,if you jumpstarted and after taking off the cables and it died after a minute or so then yeah..a alternator would be a problem.After 10 minutes??..sounds more like a bad connection somewhere.I know that the charging circuit is tied to the starter so maybe both your problems are starter related?..do one thing at a time.When you do the starter check the fuseable links down there as well.if you do the top post cross-over and really want to go all out replace both the positive/negative cables with 0 or 1 gauge wire (heavy duty stuff )especially if you relocate battery to trunk..good luck.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
