Bad Gas Milage
Old Jul 5, 2006 | 04:05 PM
Rallysport91's Avatar
Bad Gas Milage
Just looking for opionons from you guys. I have a 350 crate engine with a TPI with 3.42 gears. I noticed latey that my fuel economy has dropped off quite a bit. I haven't made any changes lately and I haven't been mashing the throttle either. Any suggestions on the sudden drop in milage? I have tested the pressure and am sitting at 45psi and replaced spark plugs and such. Is it possible to have oxygen sensors kill your milage?
Old Jul 5, 2006 | 04:09 PM
rhamm1320's Avatar
That could be a cause, does it smell 'rich' at the exhaust? Were any of the plugs fouled?
Old Jul 5, 2006 | 04:23 PM
I usually foul out plugs with a year or maybe a little more and it always smells rich..especially at start up. When I did the tpi and engine swap I don't believe I replaced the oxygen sensors and that's been about four years ago. I have always noticed the strong fuel smell...any ideas?
Old Jul 5, 2006 | 04:33 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you may want to run less fuel pressure if your still fowling plugs. and check that o2 sensor cause if it's messed up and is telling the ecu to add more fuel then it'll run rich.
Old Jul 5, 2006 | 04:36 PM
I have 23# accel injectors and I use an adjustable fuel pressure regulator. I haven't really had any issues with the milage till recently..Is it ok to back off the pressure very much with bigger injectors?
Old Jul 5, 2006 | 04:51 PM
mw66nova's Avatar
Engine: 7.0L
what do you have done to the car to justify larger than stock injectors?
Old Jul 5, 2006 | 05:03 PM
nothing as of yet..it was a foreshadowing thought. I am planning on better heads and a bigger cam and I needed new injectors so i planned ahead. I have never had a problem with them as far as killing my milage. I had another thought, I noticed my car trying to rev while I was sitting still and I wonder if my tps is going bad...will that kill your milage if it's reading the tps wrong?
Old Jul 5, 2006 | 05:41 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Was the PROM programmed for the injectors?
If not thats definately part of the problem there!
Old Jul 5, 2006 | 07:21 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Have you checked for any leaks on the exhaust sustem?
chazman
Aug 28, 2018 03:25 PM
Jae992
Aug 27, 2015 09:07 AM
chazman
Aug 22, 2015 02:01 PM
Bradsaundry
Aug 12, 2015 12:34 AM
