oil leak
Old Jul 8, 2006 | 05:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
oil leak
Fresh motor build, 1000 miles on it maybe.
I'm leaving little exxon-valdez's whenever I park the car. It drips off the oil filter type area. I don't think the oil filter itself is leaking, since there is oil higher up. The front of the oil pan is clean, so I don't think it's there. The rear few pan bolts have oil on the heads. I'm thinking maybe the oil pan gasket?
Rear main seal?
The distributor o-ring paper gasket is wet, but the area behind it doesn't seem to be, so I don't think that's it.
That leaves me with my final, and most likely candidate, the oil pressure sender. I've got a 90* bend attachment on it, and that puts the bulbous sender in a rather awkward place, it can only tighen so much, before it'll interfere with the throttle cable bracket. Right now, it's somewhat loose, I can easily loosen it by hand. I have teflon tape on the threads.
How tight should this be? Is there a spec? Is there an easy way to make this fit better? Grind the bracket? Get a 45* bend attachment?
Side note, my oil is BLACK, and it's not very old yet. I have a PCV setup. What could cause this?
-J
Old Jul 8, 2006 | 05:51 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
once oil used to leak out of my pressure sending unit,
good thing it was just that..
it only drips a few only when u rev up too,
so it was hard to tell as in idle it didnt leak.
hopefully its not the mail seal..
Old Jul 10, 2006 | 01:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
any other thoughts guys?
Im going to try and find another fitting to make this fit better.. Anybody know the thread size on this? 1/8" NPT or something?
Old Jul 18, 2006 | 04:36 AM
89 tbi bird's Avatar
Car: 89 FireChicken
Engine: TBI
1/8 should be correct
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
