Starter!!!
Old Jul 9, 2006 | 01:10 PM
1991z28camaro's Avatar
Car: 1992 RS Convertible
Engine: 5.0 L 305 TBI
Starter!!!
I have a 3.1 v6 and the starter is going , I get in the car and I get nothing all I can hear is the fuel pump and the is it . I go and turn the key and nothing happens not even a crank , I have replaced it twice with a remaufactured unit . Thanks in advance Dave
Old Jul 9, 2006 | 01:24 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Are you sure it's the starter? By that I mean is the battery fully charged? Have you checked your wiring from the battery to the starter to makes sure its tight. I had the same thing happen to me and I thought it was the starter turned out to be a bad battery. Try swith to a good charged battery and see what happens.
Old Jul 9, 2006 | 01:48 PM
Z284U2C's Avatar
Did they test the remanufactured unit when you returned it? You may have a bad starter relay as well. Did you try to jump the starter?
Old Jul 9, 2006 | 01:57 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
You should test to make sure you are getting voltage to the starter when the key is in the crank position. If you are getting power to the starter from the key, and you are getting power from the battery, try tapping the starter with a hammer while the key is in the crank position. It could also be a ground problem.
Old Jul 9, 2006 | 04:56 PM
No they did not test , just gave me a new one.
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I had the same problem...my bat. checkrd good as well as the alt. Turned out being the ground cable to the bat. Check All you connections including the grounds, This could be your problem ./..coroded cables
Old Jul 9, 2006 | 04:58 PM
The funny thing is if i let the car sit for around 10 min or so the car fires up with no probs..
Old Jul 9, 2006 | 05:53 PM
89RS&98Z28's Avatar
Car: 1989RS////1998Z28
Engine: 305////350LS1
Transmission: 700R4////4L60E
Read about Vats, got a tilt wheel could very well be the problem.
Old Jul 9, 2006 | 08:22 PM
mjshort's Avatar
Car: 82 Z28
Axle/Gears: Stock
I had a similar problem with my Z28. Starters don't like heat, really it's the soloenoid (might be why it's ok if it sits 10 minutes). My problem was the starter was too close to the headers. I got a set of Jet-Hot coated headers and it's been fine ever since. Since you have a V6, I'm not sure how close the starter is to the exhaust manifold or headers, depending on what you're running. You could get a remote soleniod, or maybe a starter heat shield. As said elsewhere in this post, check all the wiring, make sure you're getting voltage at the starter when cranking. Check the easy and cheap stuff first!
Old Jul 10, 2006 | 03:55 AM
Engine: 406
Now that sounds like heat soke....
Old Jul 15, 2006 | 06:15 AM
Many Thanks
I just want to say thankyou to all that replied to this tread . I found out it was the starter relay.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
