What am i missing here?
Old Jul 10, 2006 | 10:10 PM
Brandon Crawfor's Avatar
Car: 1982 Camaro Z28
Engine: 350 V8
to the left of the air cleaner, the black thing on the firewall has two pipes, one near the top, and one near the bottom, coming out of it.
the pipes just end, and nothing is attached/hooked up to them
ive seen pics of other camaro's engine bays and theres a silver cylinder in that area
what is it?
Old Jul 10, 2006 | 10:38 PM
Alex IROC Z-28's Avatar
Car: Camaro IROC Z-28 1987
Transmission: Automatic
that silver cilinder is the reservatory for the AC R134....and this 2 conections are for the gas goes inside of the car....to the radiator that cools down the air....
Old Jul 10, 2006 | 10:50 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Someone removed your A/C compressor, and the dryer from the looks of it. If they went to that extent, then your condenser is probably gone as well (it sits in front of the radiator). The open fittings you see are connected to the evaporator core, which will come out if you remove the top half of the black box.
Old Jul 10, 2006 | 10:55 PM
Engine: 350 V8
so can i take all that from a donor car and put it in mine? theres one in good condition in a salvage yard in the town where i live...
Old Jul 10, 2006 | 10:59 PM
It depends on the model year, as the A/C setups changed somewhat. You will have to get a new dryer if it's exposed to the open air for too long of a time. As long as the compressor turns with the clutch engaged, you should be OK.
Old Jul 10, 2006 | 11:00 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
yea but you may want to watch out for crud if your going to use any of the components that are still in your car.
Im not sure as to how a guy would go about flushing any gunk out of the condensor or evaporator. but theirs gotta be a way...
Old Jul 10, 2006 | 11:03 PM
If he gets everything from a sealed system, there shouldn't be a problem. if he intends to reuse the evaporator in his car, then take an air chuck and blow it out.
Old Jul 10, 2006 | 11:18 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Yea, i was going to say you may as well take everything from the sealed system so you know theirs no gunk in it.
Old Jul 11, 2006 | 12:11 AM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Most junkyards take the refridgerant out of the system before the cars go out on the lot, and many times the yards will take the dryer out too, so there maybe a lot of gunk in the system.
Also note whether it has been switched over from a R12 system to a R134-A system, because it will make it hella easier trying to recharge the system.
BTW, why do you want that power robbing crapola on your engine??
Maybe it is just me, but AC bothers me in my Camaro.
Old Jul 11, 2006 | 12:31 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
A working heater core?
Just messing with ya
Old Jul 11, 2006 | 01:56 PM
Engine: 350 V8
Well the only thing is, im gonna need defrost in the winter
and does this have anything to do with the heater, cuz my heater doesnt work either
lol
Old Jul 11, 2006 | 02:59 PM
Toehead's Avatar
The core is bypassed... OR missing. See the orange heater hose that is draped over the passenger strut tower.... Normally, that would go to the heater core..
Check the firewall directly to the right of the blower box, and see if you can see two little brass fitting coming out.
Old Jul 11, 2006 | 04:38 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
A THICKER AIR FILTER!!!!!That's what your missing.lol
Old Jul 13, 2006 | 01:46 PM
Engine: 350 V8
Yeah, when i get paid i plan on replacing the air filter, plugs, wires, hoses, oil, flushing the coolant, all that ****.
probably gonna get a/c parts and heater core from a donor car
and i happened to find a clutch pedal in my car yesterday, i was sitting in it for the hell of it (its not licensed yet, so i cant exactly drive it)
with no shoes on and i felt it tucked underneath the carpet
kinda pisses me off, i wish it was still a manual
the clutch pedal matches the brake and gas pedals, and its pretty well worn so im betting it came stock
Old Jul 21, 2006 | 03:36 PM
Engine: 350 V8
btw, there isnt any room under the hood for a thicker air filter, the top of the air cleaner already makes contact with the hood when its closed
Old Jul 22, 2006 | 06:24 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Yep, someone butchered you car by removing the AC and bypassing the heater core, and worst of all by putting an Auto trans in it.
Old Jul 22, 2006 | 07:07 PM
Engine: 350 V8
should i try hookin the hose back up the heater core? or could that end up bein a bad idea...
Old Jul 22, 2006 | 07:20 PM
Toehead's Avatar
Won't hurt... Just pull off the passenger side plastics and make sure it istn leaking. Or, you can try to pressure test the core.
Old Jul 22, 2006 | 07:37 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
It's bypassed for a reason, more than likely it's bad and leaking, you could get coolant all over your floorboard if you just hook it back up.
Old Jul 22, 2006 | 07:59 PM
Engine: 350 V8
BUT
if i put some sort of pan under the dash...
that would work right? if it leaks, the pan will catch the coolant
and whatever i lose i can put back, ive got some extra coolant in my garage incase id ever need it....
Old Jul 22, 2006 | 08:32 PM
bygblok's Avatar
the core is a two hour job to replace tops if you have to knowledge and the tools. As far as the A/C stuff you'd have to start from scratch. The first thing I see is the alternator mounted where the compressor usually would sit. If you can get the heater going you'll be lucky. Anything else and you've just got the bonus plan going. Time to find an a/c delete box to replace all that evaporator box and just get it over with
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
