Hot #5 HDR Primary
Old Jul 11, 2006 | 11:48 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Hot #5 HDR Primary
Ive been doing a lot of tuning lately and discovered my #5 header primary is running approx 125 deg hotter than all other cylinders. I've eliminated the injectors as culprit and am now thinking it is a valve problem? The #5 plug looks like all the others, light tan fading to white. You guys got any ideas?
Old Jul 12, 2006 | 12:38 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
intake gasket leak in that area?
Old Jul 12, 2006 | 08:51 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
I believe I eliminated a vacuum leak also. I used the Propane method all around the base of the manifold. My only thought with that is, what if it's leaking from the intake valley side? I'm not sure how to check for that? My vacuum gauge reads steady, between 11-12 in HG in Park, at idle. Keep the thoughts coming...
Old Jul 16, 2006 | 02:00 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Well despite the hot #5 header temp, I ran the car at the track yesterday. No signs of any problems while it laid down some awesome 12 sec runs. If you got any ideas why one cylinder would run so hot, send em. Thanks
no green
Jan 9, 2016 09:22 PM
thunder57
Nov 7, 2015 02:28 PM
Thaney9
Oct 24, 2015 07:26 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
