Choking below 2500rpm?
Old Jul 12, 2006 | 12:22 AM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
When i start the car after its been sitting for a while, i have no power below 2500rpm. It just chokes and tries to stall. Above it though , it will run. Also, there is erratic flat spots and choking across the whole rpm range after 2500 as well. They car still moves forward, but there is no power, and then the mentioned flat spots.
after about 15min it seems to be fine again below 2500rpm, but i still haev the same upper RPM problems. I cant figure it out.
Also, around the same time i started noticing that my temp sensor is acting weird.. like it will show unusually hot, and then all of a sudden come down to below 105, or even lower, a second later.
i cant check for codes becuase the light wont show me them if there is any(no its not burnt out). i think its a ground issue, since the wiring was recently redone for the switch to TPI from TBI.
this all started happening last friday for no apparent reason
Old Jul 12, 2006 | 12:48 AM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
I'll give it a shot. TPS sensor going bad? Any reason for the SES light not coming on even turning the key over? Kinda sounds like either TPS sensor or the coolant sensor on the intake is not reading correctly. Just a thought.
Old Jul 12, 2006 | 01:19 AM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
I dont know about the cars ,but my truck TBI has a ground wire that connected to the water outlet bolt for the T-stat..if the cars have the same thing.Did you reinstall it?
Old Jul 12, 2006 | 12:37 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
i should have put in that the car ran beautifully for almost 3 weeks before this and the swap was like 2 months ago.
throttle sensor? i tested it a couple weeks ago and it was fine... would it do something this erratic?
SES comes on during key over, but jumping the wires reveals no codes, just a solid light.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
