Are head and intake gaskets reusable?
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I'm referring to the standard Fel-Pro gaskets. 1205 intake and 1010 head gaskets. They hardly have any use on them and look to be in good shape. the intake gaskets I'm not too worried about but the headgaskets were about $40 each.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you cant reuse the headgaskets.
you SHOULDNT reuse the intake gaskets, but you can sometimes get away with it.
warning smartass LS1 owner comment below:
you can reuse every gasket on the 99+ LS1 except the headgaskets. they all use a Oring type seal.
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Head gaskets compress making them unuseable again. I HAVE gotten away with intake gaskets, but they started leaking after a while. But head gaskets are a no-no when it comes to reusing.
Car: 1991 Z28
Engine: 383
Well some head gaskets are reusable but are extremly expensive. Just didn't know if the 1010's were.
Well, since I need new gaskets
What type of head gasket works with alumnium heads??? OR which ones won't work with alumnium heads??
Actually, when the FelPro PermaTorque (blue Teflon-coated) gaskets came out in the late 70s, the FelPro rep told us they were re-useable. We laughed (duh), being accustomed to McCord and Victorcore ones that stuck to everything and tore into sawdust to remove, or steel-shim ones that were ALWAYS already blown when we took them apart, EVERY SINGLE TIME. But, not too long after that, we had some stupid thing come up late one night that required popping a head off on a car we had used them on, and we didn't have another gasket, so we took a REAL DEEP BREATH and put it back together with the old one. Surprise! It worked. So the next time we had to take that head off, we re-used it AGAIN. It worked, again!!!!! Don't know how long it might have lasted, because the motor blew up a few months later; but, that's another matter.
Which is not the same as saying that I would do it again. Especially not in a motor that I actually had to depend on to get to work and stuff like that.
The 1010 is a perfectly good choice for aluminum heads. That's what I'd use.
Car: 1991 Z28
Engine: 383
Any other cheaper alternative? I'm trying to get all my parts together for this rebuild. With a cracked lifter I think I'll go ahead and get a new set from summit, a trip to the machine shop, gaskets, oil pump, etc this is getting more expensive than I anticipated. Especially because of these damn lifters.
What type of gaskets can be used on alumnium heads?
Why are lifters costing so much? Isn't this a factory roller setup? Lifters maybe $125 a set or so? Not exactly pocket change of course, but shouldn't be enough to break the bank either, I wouldn't think....
Summit Hydraulic Roller Lifters: SUM-HT214 - summitracing.com
Oil pump, Mr G #26 spring, steel collar drive shaft, and new pickup all together is less than $30 at AutoZone.
As far as head gaskets, I don't really know of any that are any less expensive than 1010s that I'd use, except for maybe a stock FelPro head set.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Stay away from Felpro...use the GM 10105117 .(028) or12557236 (.051)
They are way better and cost alot less.
Oh...and that's my opinion (been using them for years)
Car: 1991 Z28
Engine: 383
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
i would NEVER, EVER reuse a headgasket
imagine ur new headgasket fails on u,
you have a good reason to sue the company for defective gasket,
but if u reuse the gasket and it fails on u, u have nothing to blame..
plus IMO gaskets arent that expensive and its just money/time efficient
and wise to swap a new one in whenever u go that far on opening up the engine.
Apparently Comp's can't
Personally, as I said elsewhere, I think you got hosed on those lifters. I don't think you got new ones. So don't blame it on Comp, since you have no way of knowing where they came from; blame it on the source.
It's also entirely possible, that the Summit lifters are identical to Comp ones. After all, Comp (and Crane and Lunati and whoever else) don't "make" all their parts that are the same as stock replacement, rather, they just buy them from an OEM or similar supplier, such as Eaton, Elgin, Melling, Sealed Power, etc.
Comp 987 springs aren't too stiff for any functional lifters. I wouldn't worry about it. In fact, just to illustrate the point, consider that big block lifters are absolutely identical in every way to small block ones, THE VERY SAME PART # in fact; and they seem to hold up just fine to the MUCH STIFFER big block valve springs, with higher ratio rockers to boot (probably 30-50% more force on the lifter than in your setup). Ignore the "collapsed lifter" drivel.
DynoDon...those good for alumnium heads?
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Car: 1991 Z28
Engine: 383
Nice. Looks like I'll go with those this time around.
And Summit lifters here I come. I wasn't blaiming Comp; I love their products and wish I could go 100% Comp but I can't afford it for sure. I think I got hosed too and even if these are from Comp I think they are some type of refurbish or something.
Something was defenitly fishy...
Car: 1991 Z28
Engine: 383
Dyno Don...I looked up those gaskets on gmpartsdirect and it specifies a 4" bore. Do you know if these can be used on a 4.030 bore?
Also, what about the Fel-Pro 1094's for alumnium heads. $20 a piece and they have a compressed thickness of .015!
I would never again use a FelPro gasket....too many BAD experiences with them.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
NinjaNife
Aug 23, 2015 11:49 AM
