roller lifter question
Old Jul 16, 2006 | 05:38 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I think I understand the differences between a solid roller lifter and a hydraulic roller lifter. Is there a difference between the roller cams? Are some roller cams only for solid roller lifters and some only for hydraulic roller lifters?
Old Jul 16, 2006 | 07:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
the cams meant for hydraulic rollers are slightly more tame. Err, I guess just not as aggressive I should say, still pretty aggressive. I'm pretty sure you can throw solid lifters on it, and it'll just have a bit higher redline, due to no lifter pump up.
A cam meant for solid lifters I don't think you can use roller lifters on. Might break the lifters.
hmm, actually, i'm losing confidence in my statements here, can anyone confirm/deny this? I'm thinking about it, and it just doesn't seem right...
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
