engine stumbles under load
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
first off i have a 91 305 tbi, i just got done putting on a high rise intake, got everything running again and i drove it and it starts to stumble when the revs go up. if i am just crusing the engine is fine, no stumble. also when its in neutral i can rev it as high as i want to without it doing this. only when i am hard on the gas does it do it. my timming is set between 0-2* would it help if i raised the timming a little bit?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally Posted by Air_Adam
It would... try bumping the base timing up to about 6-8* and see how it runs... should run much better.
theshackle
Sep 17, 2020 08:26 AM
