desktop dyno
Old Jul 19, 2006 | 03:18 PM
steve7589's Avatar
desktop dyno
can someone run this combo through dd for me?
327 shortblock .60 over
flattop pistons 4 valve relief
comp cams 280h 280/280 230/230 .480/480 110 lsa
L98 cylinder heads stock
edelbrock rpm intake
650 holley dp
full length headers into a 3 in exhaust single muffler system
if you can run the 327 combo and then do a L98 350 stock except for
the rpm intake 650 carb and full length headers it would help me out greatly thanks,steve
Old Jul 19, 2006 | 03:36 PM
MAD_IROC-Z_85's Avatar
Car: '85 Iroc-Z
Engine: 355cu, 11:1, 292H, 750cfm, LT1 head
Transmission: T5 non/wc
Axle/Gears: 3.73, 7.5in 10bolt posi
You must have about 320hp@5000- 350ft./lbs@3500 to 5500rpm
Old Jul 19, 2006 | 04:08 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
You will need to post the specs from your cam card to get any type of accurate reading.
Also, is it a dual plane manifold? what about your heads and valves? Need all that too.
Old Jul 19, 2006 | 04:25 PM
rhamm1320's Avatar
You will want to 'watch' your compression ratio - Those heads only have a 58cc chamber and you are 0.060 overbore. Its getting up there if you still want to stay with pump gas.
Your head gasket selection will be the deciding factor.
Virtual Engine Calculator Free Download
Old Jul 19, 2006 | 04:42 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
No, those Chambers are 64cc. Unless they are from the vettes which did have 58cc chambers.
Old Jul 19, 2006 | 05:59 PM
rhamm1320's Avatar
Thanks, good information to know. Here is where I found the 58cc - like you said - it does say for Corvette
Car Craft's Head Flow Database
Old Jul 19, 2006 | 06:53 PM
Car: '85 Iroc-Z
cast 10088113 are 58cc vette head those (this is what I have on my set-up)
these are 88 to 94 corvette head whit D shape exhaust port, I don't if they are other 58cc head butt, ...
I count 320HP and 350ft/lbs whit 9.5:1 , whit 68cc chamber
And those must have 1.94/1.5 valve
For you correct spec, please give your head cast# and that will be fine!!! Sorry!!! :-)
Old Jul 19, 2006 | 08:11 PM
steve7589's Avatar
thanks to everyone that responded.
the heads are cast iron.
this info is really helpfull,thanks again
Old Jul 21, 2006 | 12:56 PM
steve7589's Avatar
ok what if i went with a 350 L98 motor iron heads stock bore
a zz4 cam,vortec heads,dual plane intake,650 dp and full length headers.
just trying to make a decision.thanks,steve
Old Jul 21, 2006 | 01:39 PM
CHEVY_EATER's Avatar
Car: 93 Mustang GT
Engine: 5.0
HEY..want to run one for me???
stock 305 L69 with:
Performer cam w/1.6 rockers
Performer intake
Stock CCC carb
L98 D-port heads shaved .010
Dynomax 1 5/8 LT's with 2 1/2 h-pipe and Flows
I'm guessing close to 10:1 compression...
I have Desktop Dyno 2000 but that program looks like it is MUCH easier to use...
Old Jul 22, 2006 | 09:28 PM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
just postin to tag along sry guys
Old Jul 22, 2006 | 10:16 PM
vwdave's Avatar
stock 305 L69 with:
Nah, stock 305 heads are 58cc and they typically run 9.3:1 compression. Cutting 0.010 isnt going to make a difference in compression. Maybe .1-.2 at most. I would figure 9.5:1.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
