engine light and fan on problem
Old Jul 21, 2006 | 08:47 PM
eddie jr's Avatar
I am currently working on the ac system and have most components removed...this includes having the high pressure, low pressure and cycling switches unplugged as well as the wire harness attached to the evap box. Now the fan stays on all the time (this is an 85 MPFI) and the check engine light comes on sometimes when stopped or moving slow and then goes out again (haven't had time to check for the code yet).
Any idea why this stuff is happening??
Old Jul 21, 2006 | 08:51 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I remember reading somewhere that when you remove the A/C you have to jumper two wires. Do a search on A/C removal and you should be able to find it. About half way down in this post is what you are looking for. https://www.thirdgen.org/forums/tech...FC+removal+fan
Old Jul 21, 2006 | 11:15 PM
eddie jr's Avatar
Ah ha, thanks! THe high pressure cutout switch is open which is kicking the fan on. I will have to jump it until things go back in.
Any idea why a code would be thrown though?
Old Jul 22, 2006 | 05:20 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Sorry, no clue on the code. Check it and maybe I can offer some help. I assume you already know that you can check it without any special tools.
Old Jul 22, 2006 | 08:34 AM
eddie jr's Avatar
Yeah, just haven't had a chance yet. Just thought it might be an obvious issue so I thought i'd ask anyway. I will check this morning.
Old Jul 23, 2006 | 01:22 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Did you get to check codes yet?
Old Jul 23, 2006 | 09:08 AM
eddie jr's Avatar
Yeah, it was the MAT sensor. I guess it wasn't plugged in all the way? But the fan doesn't run all the time now!
thanks.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
