Acetone, octane booster??????????
Old Jul 23, 2006 | 12:56 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
After a long discussion a work, some guys had said acetone is an octane booster...
is this true?
what can/could i expect?
I have a tpi fuel system up to where the hard lines end, i have a carb... Can this damage them?
Old Jul 23, 2006 | 01:05 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
and after some reading what about toluene... suppoed to be the key ingredient in octnae boosters off the shelf...
Old Jul 23, 2006 | 02:16 PM
Yes, it is.
Yes, it really works. A slight bit. Certainly not going to turn watered down cat pee from the pump into 110 octane Sunoco race fuel, though.
No, it does not "save money" by increasing gas mileage. And even if it did, the net cost would still be higher.
Cheapest way to get it is to buy lacquer thinner at the hardware store. That is a mixture of mostly toluene and various ketones, usually acetone but maybe some methyl ethyl ketone and/or other ones.
It will strip your paint, sometimes damage rubber or plastic parts in the fuel system, and otherwise cause trouble, if used over the long term. It will also do an amazing job of cleaning the varnish out of your carb, if the concentration is high enough.
Old Jul 23, 2006 | 07:01 PM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
if your using pure acetone i suggest pre mixing it with some gas before pouring it in.... because the acetone could eat through your filler neck to your tank if its plastic!
Old Jul 23, 2006 | 09:20 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
this was talked about around this time last year....hears the thread https://www.thirdgen.org/forums/tech...hlight=acetone
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Jan 10, 2020 08:55 PM
thejimsterz28
Sep 30, 2015 08:52 PM
