Summit Valve Cover Wing bolts???
Old Jul 27, 2006 | 03:25 PM
usamuscle892's Avatar
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
Could someone tell me if I would experience any leaking or problems with a wing style bolt for the valve covers. Im gonna be getting a new polished aluminum set soon and would only use a set of wing bolts for shows, but will they leak? Summit part number:SUM-G3426
Old Jul 27, 2006 | 03:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm using the perimeter bolt style of these, with the female threads on the bottom, and it comes with the allen drive set screws to go into the heads.
They work well, no leaks.
Old Jul 27, 2006 | 09:23 PM
355yellowroc's Avatar
I've got 'em on my center bolts...the wing parts actually unscrew, allowing you to gain more length if needed...not a whole lot but enoughf for some "slightly" taller-than-stock valve covers. That's the problem I had, the stock bolts werent long enough.
No leaks...yet. Although I do have to re-tighten them occasionally.
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
