Issues with new timing chain & gears
Old Jul 30, 2006 | 01:44 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Need help fast, as I need this car running by tuesday.
Doing cam and heads, and all is going well so far.
I took off the timing chain cover and came to find out when I got the cam gear and chain removed that my Cloyes double roller chain and gear set (CLO-C3023) is a little different than my stock one. Seems that it is a tad wider and will not clear the cover. It might though, I am not sure, it will be close. Did I pick up the wrong set? It says "For non factory roller cam motors", and I read this as "I have a roller cam motor, but the cam is aftermarket" and thought this was the right part.
Anyone else use this gear set? Whats my issue here?
Old Jul 30, 2006 | 03:12 AM
ede's Avatar
ede
you have the wrong part, you have a factory roller
Old Jul 30, 2006 | 11:33 AM
Hm well hopefully I can return this, I guess I'll just go to autozone and get an OEM replacement then.
specialized
Jun 18, 2022 09:26 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
djmarch
Aug 9, 2015 05:27 PM
