New motor wont stay running
Old Jul 30, 2006 | 04:48 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
I finally got my Stealth rammed 383 started and im having some problems with keeping it running. It starts fine if i give it some gas, will rev to around 2000 rpm and then die.
Ive played with the timing, When i prime it the fuel pressure is around 40 psi, but leaks down very quickly, like 2-3 minutes. So im thinking that the injectors are leaking, but I cant see why that would cause it to not stay running. It has the stock 305TPI prom still in it ... I figured it would still atleast run with that, albeit not well.
So any help would be really appreciated
thanks
Old Jul 30, 2006 | 04:52 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
You sure that 305 computer can feed a 383?
Old Jul 30, 2006 | 07:24 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
I just figured it would atleast run..
Im gonna swap in an L98 prom until i can atleast get the tuning equipment i need,
thanks
apo_bailon15
Mar 28, 2016 05:20 AM
ezobens
Aug 19, 2015 10:29 PM
stalkier
Aug 13, 2015 12:59 PM
Sherpajames
Aug 7, 2015 06:56 PM
