Searched still not clear
Old Jul 30, 2006 | 05:16 PM
kjvail1204's Avatar
This is about carb spacers, i want to put one on my engine, but im not sure if i need a four hole or a open, im leaning toward a 1'' phenomic or how ever it is spelled. Im runing a edlebrock 600cfm carb, with edelbrock performer intake, im kindda confused on the single or dual plained intakes but im pretty sure i have a dual, (divider in the middle) well i could really use someones help on this.
Also quick tourqe converter question, I am running a stock 700-R4 i have to change out my TC and figured why go stock, im trying to find a decent TC that will wake this up a bit. Or should i just go back to stock
Old Jul 30, 2006 | 06:05 PM
kjvail1204's Avatar
No one has any insight into this
Old Jul 30, 2006 | 06:24 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
4 hole gives you more low end lower rpm torque
open one gives you power at higher rpm top end
why do you want a spacr so bad
what kind of rpm range do you drive in
what is your axle ratio
do you have any extra stall in the converter
you may want to save yourself trouble installing a spacer if you really dont need one
as far as getting the cables ot work its a matter of plannign and being creative and patient and good with your hands and tools and pieces of metal and such
we need details fro you
good luck
Old Aug 7, 2006 | 11:33 AM
kjvail1204's Avatar
The converter is/was stock, when i droped the transmission i droped the TC and there was metal glitter in the fluid in the TC. So im going to go ahead and replace it so im was wondering what a good stall is, im not looking for draging but more like city driving, (average MPH is 40-45) my rear end gear is 2.73 stock
Old Aug 7, 2006 | 07:59 PM
IROCZ86's Avatar
Car: 96 SS #15
Engine: LT 1
Transmission: M6
Axle/Gears: 3.42 ZT
Number one, the Fluid in your TC doesnt STAY in your TC. The only reason you put fluid in your TC to start is for Starting pruposes. If you have Sliver Glitter in your TC you Have Silver Glitter in you Transmission. Did you pull the pan on the tranny??? Check the Flitler for Metal shavings or look at the Magnet.
TWO if you dont know WHY you need a Spacer for your Carb then you more than likely dont need one. It sounds like your Car is just a Driver and not a real power hungry Monster. Keep things simple until you do some more study. Dont get in over your head. I know alot of guys that think you use a spacer to raise the Carb up to clear your "dist" with your Air Cleaner.
cowansauto
Apr 3, 2025 12:51 PM
wigmobile
Feb 26, 2025 02:56 PM
sahlomonic
Sep 20, 2015 07:15 PM
Mdenz3
Sep 17, 2015 08:36 AM
BOOT77
Sep 16, 2015 08:37 PM
