Off of compression stroke?
Old Aug 1, 2006 | 07:05 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
What do I have to do to get my car off of a compression stroke
The car is a 84 firebird with lg4 its just a long block right now in the car..
Old Aug 1, 2006 | 07:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Get it off a compression stroke?
Old Aug 2, 2006 | 01:40 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
how?
Old Aug 2, 2006 | 01:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm trying to figure out what you mean. At any time there's always a cylinder that's on a compression stroke.
Old Aug 4, 2006 | 03:27 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
My car shoots gas outa the carb
Old Aug 4, 2006 | 03:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
When you try to start it? Check your distributor position and firing order.
Old Aug 4, 2006 | 05:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
oh, and make sure you get it off a compression stroke
Old Aug 4, 2006 | 09:47 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Now now...
Old Aug 4, 2006 | 10:07 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
You're from Jersey, that would partially explain the English thing....
Do you mean to ask, how does one get the engine off the compression stroke in relation to the position of the distributor? If you think you stuck the the dizzy in wrong (on the compression stroke instead of the power/fire stroke or more TGOish dot to dot on the set) and you want to check it swap (read:rotate) the wires around to shift #1 to the #6 spot. If you really want to fit in with the TGO crowd thereafter, leave it like that so it's a 'cool mod' so it'll freak out the next guy that has to mess with it...
...or you could do it the right way and just pull the dizzy and restab it the right way (this would involve pulling out the dizzy, rotating the motor and reinstalling said dizzy).
junior419
Apr 7, 2025 11:35 AM
FormulasOnly
Jul 23, 2018 08:47 AM
randy210
Oct 15, 2015 03:43 PM
dusterbd
Sep 29, 2015 08:40 AM
WhteRbt
Sep 21, 2015 09:48 AM
