Could motor mounts cause the car to feel shakey at idle?
Subscribe
Aug 1, 2006 | 09:51 PM
I am gonna be getting a brake job (you can thank Brake Masters and their half assed work for this) tomorrow and I was gonna tell the guy to check my motor mounts for me.
I remember from awhile back when I checked my motor mounts, they were in pretty beat up condition, I was just wondering if a worn motor mount can cause a car to be shakey at idle.
If I get those replaced would the car be smoother to drive or no?
Reply 0
Aug 2, 2006 | 05:19 PM
Quote: awhile back when I checked my motor mounts, they were in pretty beat up condition, I was just wondering if a worn motor mount can cause a car to be shakey at idle. If I get those replaced would the car be smoother to drive or no?
Possible, yes. Have someone observe the motor as you romp it a bit. If the motor rocks, could be.
JamesC
Reply 0
Aug 2, 2006 | 07:05 PM
depends
If your stock or close to it, then yes its possible
But if you have a huge cam then thats normal.
Reply 0
Aug 3, 2006 | 10:58 PM
also depends on how loose the motor is
Reply 0
Aug 4, 2006 | 12:49 PM
The motor in my old 86 IROC was shaky, until one day with the hood up was looking at the motor and stuck it in reverse, I bet the motor jumped 2 inches on one side, found that the motor mount was from a 6.2 diesel and ended up sticking one long a$$ bolt all the way through it. Does the motor hesitate? Could be something on the ignition side, one fouled plug or bad cap would cause it also.
Reply 0
Subscribe
