factory 69-79 350 oil stick tube question
Old Aug 2, 2006 | 07:42 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
on a factory 350 in the 69-79 years can someone tell me if the end of the oil stick tube(that press fits into the engine block hole) is belled out or anything else other than the exact same diameter as the rest of the stick ?
trying to determine if the reason why this one factory tube is too small for the hole in the block of the 74 350 i have
thanks for anything
Old Aug 2, 2006 | 08:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Same size all the way down, IIRC. I can find mine and check though.
Old Aug 2, 2006 | 08:30 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
it probably is as you recal it is im sure
if so then it means there was more than one size in 69-79
some of these years were smaller tube diameter
hmmm
anyone know what years were larger and what ones were smaller ??
maybe it was an engine size deal..
69-79 hmm that would be 307 327 350 400, hmmm
is it possible the 307 ones were the smallest,
that could be what this one is from, actually it could be VERY possioble that this tube( that is too small for this 74 350) is from the '68 307 in my first chevy i ever had- when i was 16- IE my 68 c-10 pickup after i blew up the original 307 2bbl and completely dismantled it- it blew the #1 rod out the side...
thanks for anything
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Leggman1
Aug 6, 2015 04:15 AM
