backfiring and randomly dying
Old Aug 3, 2006 | 04:19 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
today i was driving home from work and my freind in his formula was behind me and i decided to show off by slamming the gas to the floor and leave him in the dusst, then it kinda died then backfired and was running agian! and a few days eairly i was driving and i hit a pretty bad pothole and the car just shut off. i was able to start it up very easily . thinking i had a bad ground i checked my wires and cleand up the contact areas but that must not be it! cause it still dies on huge bumps. also about a month ago i replaced a crank sensor because of a code 43 after that it drove good and didnt get a code..... not sure if this has anything to do with whats going on now though.
Old Aug 3, 2006 | 04:31 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
did you check to see if your computer contacts are clean/ connected all the way? this is a common problem....
Old Aug 3, 2006 | 08:45 PM
Engine: 350 tpi
i just checked pretty much all connections and they look good and i just put dialelectric grease in all my connections maybe this may help? ill have to lay on the gas tomorrow morning before work and see what happens. ill throw it on the diagnostic computer at work too and see if i can find any problems.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Luigytico09
Oct 1, 2015 08:46 AM
