1987 305 4bbl Head Gasket?
Old Aug 6, 2006 | 04:20 PM
barrett's Avatar
I am not sure what is going on with my engine. When picked it up I changed the oil and noticed about 2 cups of coolant that came out. I have since driven the car about 30 miles again and there is no coolant in the oil and no white smoke from the exhaust and no oil in the radiator. Whats going on? Can anyone help me?
Old Aug 7, 2006 | 12:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
when you picked it up? you mean bought it?
Then who knows what happened to it before, but if the problem is gone, i'd turn a blind eye, and be happy
Old Aug 7, 2006 | 08:01 PM
IROCZ86's Avatar
Car: 96 SS #15
Engine: LT 1
Transmission: M6
Axle/Gears: 3.42 ZT
It is possible someone DID blow a head gasket changed it, Got a ton of Coolent in the lifter Valley and just didnt change the oil before they sold it.
Old Aug 7, 2006 | 08:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'd do a leakdown test just to be sure.
Old Aug 9, 2006 | 07:38 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yeah water in the oil is not good usually, is at least a bad gasket in intake or head, or can b a cracked head or intake
dont be running it til you figure it out
i would suspect bad intake gasket first and go from there
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
