2055's and Fan Switch Relay
OK, what are you guys with Hooker 2055's doing to keep your Fan switch relay from getting toasted?
I burned mine off (literally) and now need to replace the sensor and the plug/wire. It is in a terrible position because it almost directly lands on the header.
I am thinking about buying some heavy duty abestos wrap to put around the wire, but not sure if thats going to save the plug/sensor....
Thoughts / pictures of what people have done here would be greatly appreciated.
Transmission: 4L80E/4L80E
The relay is on the firewall. How are you burning it with headers?
Or, did you mean the temp switch? Tucked the wire behind the starter wires.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i think he means the connector for the fan switch. i too with the 2055's melted the connector. i just replaced it and see how loong it lasts.
Well, yes, it comes close on mine, I bent the wire as close to the connector as I could and tucked it away from the tube as best I could. Ran that way from 2000-2004.
My headers are now coated. That helps.
