help in this new set up
Old Aug 10, 2006 | 10:31 PM
Thug Life's Avatar
guys i need help in this et up
4.060 pistons,corvette heads 416 or a number like this cant remember,lunati cam shaft 555" 106 lobe or 535" 110 lobe,performer RPM for Q-jet,GM Q-jet,headers,TH-350 with shift kit,3.42 ratio
what r the numbers of this set up?is it good or bad b/c my brother used to have 80 step side chevrolet C-10 with 4.060,vette heads,lunati cam 535" 110 lobe and Q-jet and it was awesome so im thinking of the same set up or something very good for street/strip
need ur help here
Old Aug 11, 2006 | 01:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What is your question? Guestimated HP?
Sounds like an alright combo. Find out what the heads are, 416's are 305 heads, and "corvette" heads could be anything. Get more info on the cam, lift doesn't really tell the whole story.
Somewhat similar to my combo. ie, 416 heads, performer RPM q-jet, qjet, compxe 268, etc.
It's a good low buck motor build.
Old Aug 11, 2006 | 02:18 PM
Thug Life's Avatar
well my brother told me a number something like 416 and the cam shaft spec was 555" and 110 lobe,Q-jet,,etc
but u know what i need a combo that is a very good for street/strip and wont let me down
i was thinking of 4.060 pistons,sportsman II heads,555" 106 lobe lunati cam shaft,air gab intake manifold,long tube headers,holley carburetor and some other things
u tell me the best set up for street/strip and the car not for daily use and i want rough cam shaft i love the sound of it
Old Aug 11, 2006 | 08:20 PM
Thug Life's Avatar
btw im thinking of putting a T-5 on that set up with 3.73,how good is this will be? or should i go to TH-350 directly?
in my country the fastest stock cars are avalon's,altima's,350Z's and some modded mustang's they are crap cars and i want a killer set up for them and some modded cars
i asked my brother about the old set up in his old truck he told me i ate 300ZX turbo and iroc z with some serious mods alive and i still have the car i will eat 350Z's and altima's for breakfast
is it true with this set up u can beat those japanese bugs?
Old Aug 11, 2006 | 09:25 PM
That depends on what your heads and cam actually are, among other things. (Driver, gears, driver, carb, tire, suspension, driver, and so on)
Oh, and with a stick shift, the DRIVER is real important too. One slip by the driver and it's all over.
Old Aug 12, 2006 | 10:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
What country is this anyway?
yea, that's all just talk, you really don't know anything about that motor yet... I mean, I can chirp all 4 gears... boy that impresses people I tell it to. Does that mean my car is fast? Not really. Did that raise your eyebrows? Probably. But who cares? That just means I need to tune my suspension really.
Old Aug 12, 2006 | 04:18 PM
Thug Life's Avatar
its in middle east
but u dont know those ppl here they always like "come on show me what u got" and i really dont want to race them with a 305 !!
their cars are brand new with racing fuel thats why they seems they rule the street but in the end they are *****'s,not to mention all those honda's,stang's,alot of stang's all show off and always says "no chevy can take us in 1/4 mile's",man its so insaulting i love chevy and i dont want those suckers to talk alot about chevy's,well see 350Z's,altima's,,etc all those *****'s i can eat them with that set up b/c there is already an iroc z ate them for dinner yesterday and his set up is 4.040 sealed power pistons,converted from tpi to q-jet and a unknown cam shaft but not rough at all with Th-350 and 9 bolt rear end with stock 3.27
right for now i will go with sealed power 4.060,lunati cam shaft 555" lift and 106 lobe,performer rpm for spreadbore,q-jet and about the tranny im all confused go to manual or stay on auto and for the rear end it will be 3.73 hopefully
Old Aug 12, 2006 | 04:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
don't go 4.060 just for fun, bore it as needed. Only to clean up the bores, those 4 cubes aren't worth the risk cracking your block.
Old Aug 12, 2006 | 04:23 PM
Thug Life's Avatar
then help me man i really need a help,im confused :'(
i want pistons with high pressure and i really mean high around 11-12.5cr
my brothers old set up got 12.5:1 pressure
he already got 4.030 in his garage but i dont know about the C/R
Old Aug 12, 2006 | 04:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
the piston overbore size has very little to do with how much power you'll get.
Why so high? You actually do have race gas at the pumps over there? Is this in Dubai?
use small chamber heads like 56cc or something. It sounds like you really don't know much about this, i'd read some books and start slow here.
Old Aug 12, 2006 | 05:06 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
As far as your cam goes.....a 106 is a pretty nasty lobe angle, I can't see recommending going quite that tight. 110-112 seems to do well for a street car, and doesn't bother fuel injection systems quite so much. You can go tighter on a carbureted car, but I don't know how far you could go reasonably.
I'm running 224/232 duration, .533/.544 lift, on a 112 angle on a 302 and it's a pretty big cam for this motor and performs like **** on the street until you wind it real tight. So I imagine on a 350, you'd be looking for something pretty similar, maybe a tad bigger, for a hot street project.
By the way, what's the duration at .050, youre not posting those. Just from what you said, for a street setup I'd go with the .535 lift, 110 LSA cam. IMO.
Old Aug 12, 2006 | 07:07 PM
Thug Life's Avatar
Sonix no its not Dubai,its bahrain and no we dont pump a race gas in the pumps,we got Torco,VP racing,,etc racing fuel over here and i found them a little cheap
Nixon1 thanks for ur help,well i dont have all the spec's thats why i didnt post them cuz all i know till now is 535 lift and 110 LSA i will try to get the duration of both cam's
Old Aug 13, 2006 | 11:20 AM
Thug Life's Avatar
this is my last question
how can i know the LSA of a cam by its spec
lets say 234/244 duraition 488/510 lift
i asked a guy he told me there is a calculation something like 234+244 then he dont remember the rest of them
so what is the calculation?
Old Aug 13, 2006 | 01:25 PM
Sonix's Avatar
Car: 1982 Trans-Am
just look it up. Oh, and forget that cam, it's bull****.
Old Aug 13, 2006 | 04:33 PM
Nixon1's Avatar
Lotta duration...maybe a higher rpm cam? Yea I wouldnt use it either
Old Aug 13, 2006 | 08:55 PM
Thug Life's Avatar
ok now im all confused
i asked for a calculation how to get a lobe seperation from an example 234/244 duration @ .050" ; 290/297 advertised duraton
i dont want this cam shaft im just givin the spec to know the calculation from it
Old Aug 14, 2006 | 12:44 AM
Sonix's Avatar
Car: 1982 Trans-Am
you can't get the LSA from the duration spec. That cam could be ground on a 106, 110, 114 or 107.75*, any oddball number you want.
You can get the lobe centerline angle from that I think, but that's kinda meaningless right now.
Old Aug 14, 2006 | 12:48 AM
Thug Life's Avatar
yeah i know how to get the lobe center line from opening valve+close valve,,,etc
ooh i see,but what if i found a good cam shaft in summit and i want to know the lobe seperation of it
Old Aug 14, 2006 | 12:52 AM
Sonix's Avatar
Car: 1982 Trans-Am
name the cam.
it's usually listed, or you can search on that part number on the actual manufacturers website, and find the cam card, and it'll be on that.
Old Aug 14, 2006 | 12:55 AM
Thug Life's Avatar
thanx alot i found that now,lol
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
