Fix Oil Leak - now ticking sound under car?
Old Aug 12, 2006 | 03:55 PM
True's Avatar
Car: '85 Z28
Engine: Need one. =(
Hello again all,
Just got my oil leak fixed last night - loose oil pan and (where most of it was coming from) loose oil filter
Tightened those up, and the valve covers too, and now I have a ticking sound coming from under the car. Never had it before, only had it after having these things done did it occur. Seemed to drive fine home, although I didn't go over 1800rpm Don't really want to drive it anymore without knowing what the issue could be...
The ticking goes from inaudible to barely / somewhat audible at idle, and only gets fairly loud >1500-2000rpm. I can faintly hear ticking at idle inside the car. There is no noise from the top...
If you need it, I can probably record it for you.
Any ideas?
Old Aug 12, 2006 | 03:58 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Originally Posted by True
Hello again all,
Any ideas?
A BOMB
Old Aug 12, 2006 | 04:28 PM
True's Avatar
Car: '85 Z28
That's really no help. This issue is really stressing me as it is.
I had a Chevy geek come look and listen to it; it wasn't ticking, but he heard something else and thinks it is a spun rod bearing.
He's got a few motors and some okay prices for them + installation, so I may have to do that - but I don't have any money so this is going to be quite difficult. He's got a rebuilt 350 and a new 350 ready for installation, if only I had more money I'd have him drop one in right away...
If anyone else has any ideas either, feel free to chime in.
Old Aug 12, 2006 | 05:01 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
How low did the oil get when it was leaking? Ever lose oil pressure?
It's pretty unlikely that a noise like that will have any relation to what you did , unless during the period where it was leaking, it went low on oil and something was damaged...
A spun bearing will make a pretty good sound and it definitely isn't going to get any quieter. IIRC, a spun rod bearing won't affect oil pressure, but a cam or main bearing will. But I might be wrong, I'm a bit out of my game when it comes to internals, I slapped mine together and got lucky.
Old Aug 12, 2006 | 05:48 PM
True's Avatar
Car: '85 Z28
I did loose oil pressure. Oil ended up getting quite low. Not losing pressure now...
Plausible that this is it.
Old Aug 12, 2006 | 05:50 PM
Nixon1's Avatar
Yeah, if you lost oil pressure....I can definitely see bearing damage as a likely possibility.
Old Aug 12, 2006 | 05:58 PM
True's Avatar
Car: '85 Z28
Guess it's time to save up... Be without a car or much transportation for a month or two =(
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
