engine compression
Old Aug 17, 2006 | 06:57 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
engine compression
well i got a 305 and my budy who does my engine work says dont put no more money tring to get my engine to work right , he sais the engine compressions off and it aint worth putting time and money into a 305 (which i dont blame him) but i dont have any extra cash for a new engine and my other budy wont be selling me his 350/th350 casue he got a new toy to play with
here is what it does , turn key and its cranks very very fast dont start , turn key back to off and turn it back o0n same thing turn it off and turn it back on and it fires right up (t6hats what i been sinking my money into fixing that) and he said the heads arnt getting the sealed oil to give the engine its needed compression what can be done to fix this i might as well just start saving up for a new camaro but this one has no body damage or rust any were best body i ever seen beisdes it needs a new paintjob but hey who's dont
Old Aug 17, 2006 | 07:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The correct way to find out if it has compression problems would be to do a compression test with a compression gauge.
Old Aug 17, 2006 | 08:05 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
after checking the compression, i would take a look at fuel pressure, it kind of sounds like you have none until the oil pressure builds up enough to close the oil pressure switch or like the pump is priming too slow.
Old Aug 18, 2006 | 05:36 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
well i got new fuel lines pump and filter , sending and reciving lines are also done but thanks i will look into the comp test
Old Aug 20, 2006 | 01:03 AM
bitchin85camaro's Avatar
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
do a compression test for sure. all cylinders should be atleast with in 10% also check for oil in your coolant, or vice versa. sounds like if the motor is shot it would be worth droping a motor in if you like the car, if not ditch it.
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
