Oil pressure sending unit.
Old Aug 18, 2006 | 10:05 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
How do I get this thing back in there? I just installed my Hooker 2210 headers last night, and I can't get in there to tighten that sensor down. Any ideas? Tools?
Zach
Old Aug 18, 2006 | 03:18 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Zach
Did you remove the sending unit to install the header, or for some other reason? My edelbrock headers get right in the way as well, however I found I was able to get to the sending unit boss from underneath the car. It can be a tight fit. I was able to use a crescent wrench on mine, but then again I'm not sure of the design differences between yours and my edelbrocks.
Old Aug 20, 2006 | 07:46 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can also put a plug in there, and move the OPSU to the top. On the china wall, to the driver side of the distributor, in the top of the block there is a small hole that should be plugged - you can relocate the OPSU there, with some brass adapters/fittings and an elbow - that's where mine is on my 1992 RS with old school carbed 350. Would solve the header issue.
Old Aug 21, 2006 | 08:42 AM
Car: 91 Firebird
Engine: Turbo 355
I couldn't get the cresent wrench in there. I could relocate it to the top I guess. I will try to get some adapters.
Zach
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
