engine work killin me!!!!!!!!
Old Aug 18, 2006 | 08:44 PM
pandemic_ratio's Avatar
Car: 1992 RS Camaro
Engine: 350 small block V8
Transmission: icky automatic
if i didnt love my camaro so much i wouldnt even bother... i had to pull the whole top and front of the engine apart. its a 305 v8 but the prob is its got all that emissions **** in the way!!! ahhhh i hate emissions. seriously who the heck needs or wants an air pump...not to mention what good would it really do seriously!!! well i did get it all apart but it sucked...now that ive gotten a valve job and changed the timing chain, spark plugs and spark plug wires (all with the motor in he car i might add) i just need to get it all back together im so close to finished and off all things i loose a damn water pump bolt!!!!! uggh...oh well it will get finished soon enough.
Old Aug 19, 2006 | 12:31 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Not to be a jerk, but what is the point of this thread? Do you have a question? Or are you making a statement?
Old Aug 19, 2006 | 05:19 PM
Car: 1992 RS Camaro
oops...
yeah sorry i did have a question i just failed to put it in there...i was gonna ask if there was a way to bypass my air pump w/out having to change the whole bracket?
Old Aug 20, 2006 | 07:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Smog pump: https://www.thirdgen.org/serpentine
Lotsa goodies in the tech section!
Old Aug 20, 2006 | 08:00 PM
Car: 1992 RS Camaro
thank you but i have TBI fuel injection and my O2 sensor will read rich when i remove the air pump, is there somthing i could do about that or do i just have to put up with the check engine light on all the time?
Old Aug 21, 2006 | 08:00 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Ah!!, Not so, my man. The computer will adjust fuel mixture by what it sees at the O2 sensor. No check engine lite. Many folks have removed the AIR system with out a problem.
Old Aug 21, 2006 | 12:59 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
So, you removed the pump temporarily and the O2 started to run rich??
Sounds like a seperate problem, honestly. I don't see how only removing the pump would make a change like that.
You might start by replacing the o2 if it has any milage on it. Other than that, some more exploratory work needs to be done to fix your problem.
Old Aug 21, 2006 | 01:31 PM
Car: 1992 RS Camaro
well my step father has been a mechanic for some years but he worked on alot older models than what i have so it was a guess by him that the O2 would run rich...so i was just checking around to make sure....but if it does run rich i will look into it though so thank you for the tip.
Old Aug 21, 2006 | 01:40 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
theres no gain to be had by removing the AIR system
at all
zero, none
if its all intact and working fine then kjust save yourself the trouble and leave it be
for real
trust me
worry about more important things than the AIR system, it is there to burn unburnt fuel fumes in the exhaust, it has nothing to do with performance of the engine nor does it take any of it away, at all,
plus it helps to keep the world's air a little bit cleaner
i only remove AIR systems if the tubes are broken corroded apart or the pump is locked up or something else bad
otherwise theres no point in it
just trying ot help, as i have been here done this a million times over theyears,
good luck
Old Aug 21, 2006 | 09:46 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
in addition to what Fast68 said, what happens when you get emissions testing?
then you have to turn around & put everything back on.
emissions testing is not a question of " IF ", but one of " WHEN " you start having to do it.
Old Aug 21, 2006 | 10:32 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
at all
zero, none
for real
trust me
good luck
You missed the part where the A.I.R system is ugly as hell and makes the engine bay more cluttered.
Old Aug 22, 2006 | 02:43 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Mentally challenged kids are ugly as hell at make schools more cluttered, but we don't get rid of them, do we?
[/badanalogy]
But seriously. Get over it. It's a little more work, and your kids might not have to live in the oceans for a few more years.
Edit: I dunno. I just looked up a reman, and if you took a sander to it, made it smooth and curvy, and painted it high gloss black, it could be a pretty sweet lookin part. Pop your hood after you beat someone's ***. "What's that shiny black part down there? Is that what beat me?!" "Nope. That makes me emmissions compliant. I WHUPPED YA WITH EMMISSIONS!"
I dunno. That'd be sweet.
Old Aug 22, 2006 | 06:07 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
[/badanalogy]
Might as well tell them you beat them with a 305 might hold more weight than emissions...
Old Aug 22, 2006 | 11:29 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Many posters here are retarded too, and do dumb things to their cars.
The o2 offset in $8d is .100mv.. Not enough to run so lean that you'd blow something up, but it still assumes air when the bit is set.
-- Joe
Old Aug 22, 2006 | 01:03 PM
Axle/Gears: 3.27 BW
Well, removing all of the emissions equipment is the first thing every young import driver thinks they need to do. And it's just unessacery to remove. No matter what, one day you will have to pass emissions, and it WILL have to be there. The only reason classic cars don't need them now, is because they weren't original equipment. Some cars don't need seatbelts, because they didn't come with them.
Last edited by TheScaryOne; Aug 22, 2006 at 01:04 PM. Reason: Changed my "preferencial" slur to import driver.
Old Aug 22, 2006 | 03:14 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I am not against emissions, do i have emissions? no, but i did a v6 to v8 swap and i was not going to spend money on buying something i didn't need.
my opinion is that the AIR system is not required, clutters the engine bay, and makes it a pita for things like plug wires, certain hoses etc. So I cut mine off my headers and welded the holes. i know plenty of 500 hp full emission cars, but like I said, it is in the way for some people.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
