L98 engine details help
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
. The stock iron L98 heads (castings 083) had 64cc chambers and 1.94/1.5 valves. Static compression should be right around 9.3:1. I cannot recall the stock dish off hand but quick use of the search function should yeild you all of the answers you are in search of.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
87-89 L98's had 9.3:1 compression, but the 90-92's had flat top pistons which bumped compression up closer to 9.7:1. That's partly the reason for the 5 more HP. (the other reason is the switch to speed density and eliminating the restrictive small MAF)
1988iroc350tpi
Aug 14, 2015 07:52 PM
