somethings wrong!!
Old Aug 21, 2006 | 07:14 PM
90IROCJustin's Avatar
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
somethings wrong!!
Im having problems with my IROC right now.. it shakes when i give it gas or when im driving for that matter and i dont know whats wrong with it.. it was fine the other day when i had it out and its been like this for the past few days.
Any ideas?
thx
Old Aug 21, 2006 | 07:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
did you do any recent work on it? if the shake is always there check the driveshaft. is the car shaking or is the motor shaking the car, might be missing. something to look at
Old Aug 21, 2006 | 07:21 PM
yea i had some exhaust work last wednesday. and sometimes it doesnt do it but it will just start all of a sudden
Old Aug 21, 2006 | 07:22 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Is it running poorly?
Old Aug 21, 2006 | 07:24 PM
when it shakes yea it runs poorly, but i can hear it in the exhaust, it sounds choppy when it gets shaky
Old Aug 21, 2006 | 07:33 PM
Car: 84' Trans Am
I was going to say check you plug wires, mine was missing and studdering when acelerating, if that doesnt help chances are its the plugs.
Old Aug 21, 2006 | 08:01 PM
yea the plugs are pretty old, i never did change them after it sat for a couple years
Old Aug 21, 2006 | 09:34 PM
i was just talking to a mechanic i know and he said i should get an injector flush and if that doesnt work he said i prolly need new injectors.. how much does it cost?
Old Aug 21, 2006 | 09:42 PM
Car: 84' Trans Am
The plugs are probaly the problem, injector flush? never heard of that, nothing alittle sea foam or injector cleaner cant fix.
Old Aug 22, 2006 | 08:28 PM
Plugs are good, and injector cleaner didnt do it.
when it gets shaky like that the needle on the tac skips when it hits about 2500 -3500 rpm
Old Aug 22, 2006 | 08:32 PM
Car: 84' Trans Am
Plug wires maybe, my spark plugs looked good too but really from the car sitting really took its toll.
Old Aug 22, 2006 | 09:36 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
There would be a lot I would check before I would assume the injectors are bad. First check fuel pressure and the resistance across each fuel injector. Does the car shake at idle, or only over a certain RPM? Also, what kind of exhaust work? If it was up by the engine they may have routed your wires poorly causing one to sit on your manifolds and burn through. Injectors may be your problem, but would not be my first suspect.
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Dyno Don
Jan 24, 2016 08:24 AM
TheTraut88
Sep 11, 2015 05:16 AM
