Ring and Pinion install help???
Old Aug 24, 2006 | 09:27 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
I have an 89 RS that came from the factory with 2.73's and an open carrier. I recently aquired a eaton posi and a set of 3.73's. I need some help/ advice with installation. I know that the install of rear end gears is not by any means easy, but i also understand it is not impossable. does anybody know what i should do, being have an experienced pro do it. Or does anybody know where i can get the resorces to do this myself, such as videos, good install instructions, or a company i can call for help? please help????
Old Aug 24, 2006 | 10:19 PM
camarodubs's Avatar
Car: 1987 camaro
Engine: gm goodwrench crate 350 mild
Axle/Gears: 28 spline 7.625 10 bolt w/273
hey man I just did a gear swap in my 88 camaro and it wasnt bad at all the tricky part is setting the backlash on the pinon gear. I didnt have to do this , but I know it is hard to get the backlash set properly and I know you have to use a dial indicator and set the gap between the gears from 7 to 10 thousandths and thats all I know about that, but I could explain to you how to install the carrier with no sweat
Old Aug 25, 2006 | 02:55 AM
ede's Avatar
ede
it's way easier to do than most think. bad part is it requires tools most people don't have. look in a manual for a how to, or even the instructions that came with the gear set.
you need to:
1 set pinion depth, hone out the old bearing so you can slip it on and off when you know what shim to use press on the new bearing, you need a press and bearing spliter, pinion dept tool or depth mic and something to use for a datum surface, i use flat piece of aluminum
2 install pinion and set pre load, you need a dial type in/lb torque wrench plus some sort of "special tool" to hold the yoke ,flat piece of steel with a couple of holes in it works good
3 install carrier and check back lash, you need mag base and indicator
4 and finially check the contact pattern, but i wouldn't get all wrapped up in it if the numbers hit it'll be good.
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
hectre13
Aug 26, 2015 08:17 AM
89fast5oh
Aug 24, 2015 08:14 AM
