antifreze in my oil!!!!!!!
Old Aug 24, 2006 | 10:05 PM
rodrigo diaz's Avatar
Car: 92 rs
Engine: 5.0
Transmission: 5 speeds
hi guys i checked my oil this moring and it look like chocolate milk i think i blew a head or a manifold gasket it wasn`t like that 5 days ago and i haven`t driven the car for more than 15 miles . do you think i hurt the engine ?am going to take the manifold out to take a better look at it let you guys know what happened
Old Aug 24, 2006 | 10:25 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Could be something as simple as a leaky intake gasket, to something as extensive as a crack/hole in the head or block. Run a compression check and see where you're at.
Old Aug 24, 2006 | 10:27 PM
Car: 92 rs
Engine: 5.0
tomorrow morning
Old Aug 24, 2006 | 10:46 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
1) Intake gasket leak
2) Head gasket blown
3) Cracked head
4) Cracked water jacket in block
Old Aug 24, 2006 | 10:53 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Sounds like a head gasket to me, it should be ok just don't drive it anymore!
Old Aug 25, 2006 | 09:41 PM
Car: 92 rs
Engine: 5.0
well i took it apart it, was a manifold gasket it was cracked at one end i will clean it and put it back tomorrow , how should i flush all that contaminated oil out of the rest of the engine?and any other tips on doing this apreciated!!! thanxs guys.
Old Aug 25, 2006 | 11:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
well, drain the oil now. Once it's all buttoned back up, refill the coolant, and put in new oil. Shouldn't have to really worry about flushing it I wouldn't think. You can drive it for a few days, and change the oil again if you want.
The oil will sink to the bottom, and drain out first.
Also, the water in the oil will heat up and boil, and steam, then go out your PCV and out the tailpipe. Or out the oil fill hole as steam.
Old Aug 25, 2006 | 11:58 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you are going to need ot change the oil and filter several times very often,
water is VERY not good for the bearings and such, at all,
hope its ok though, wont know for a while probably though
good luck
Old Aug 26, 2006 | 02:13 AM
EvilCartman's Avatar
Car: '82 Z28
You mean the water will settle to the bottom and come out first, right?
Old Aug 26, 2006 | 10:43 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Fast68: Are you looking for the 15" N24 wheels?
Old Aug 26, 2006 | 12:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
yes, that's what I meant. Oil floats on water - hence the oil covered birds you always see on the 6 o'clock news...That's a good way to remember it.
Old Aug 26, 2006 | 05:17 PM
Car: '82 Z28
Exxon Valdez
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
