camaro won't start. HELP!!
Old Aug 25, 2006 | 10:58 AM
iloveslayer's Avatar
Car: 89 iroc 350
Engine: 350 tpi
My camaro (89 iroc l98 auto) sat in front of my house for a while would start every time I needed it to but all of a sudden when I go to sell it. nothing. not a peep. changed battery. still nothing. the problem seems electrical like the juice isn't getting to the starter. starter does not click. Ive put the battery on the charger overnite to make sure and it's just dead . battery gauge stays on the line between 8 and 13 (11?) Could this be the chip in the key? do they wear out? or does the ignition switch seem more likely ? Also, the acc fuse keeps popping but after reading into it that doesn't seem to be the culprit. is this a correct assumption? I just want to fix this p.o.s. for cheap and get rid of it. my '87 bird is so much better. lemme know.
Old Aug 25, 2006 | 11:04 AM
j dezzy's Avatar
Car: 87 TA
have you checked the starter?
Old Aug 25, 2006 | 11:27 AM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
either a wire is shorting out on the chassis, which is causing the fuse to pop, yea, i had the same problem with my car, new batt and everything, it turned out the ground to the starter got to hot and melted, so we made a new ground to the starter, after that it ran fine.
Old Aug 25, 2006 | 04:02 PM
Bigdeath's Avatar
Car: 89 RS 305
Engine: 5.0 305 tbi
could very well be a VATS issue. Does the security light come on?
Derick15
Sep 17, 2016 05:28 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
