Car Jerking - Running Lean?
Old Aug 29, 2006 | 05:18 PM
huntingwood's Avatar
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
So my car doesn't seem to be running quite right. It generally runs kind of rough, but when I'm accelerating very slowly, around 45 mph, the car will sometimes start sputtering and jerking. If I give it more gas I can acclerate out of it. Also, once in awhile there is a loud pop out of the exhaust. I originally thought I might be running rich because of the smell (no cat) and the fact that eventually black stuff builds up on the ground effects where the exhaust is, although that takes a long time. I put the car in field service mode, and the light was flashing slow, which means the car is running lean I think. Engine is a 350 tpi, the previous owner blocked off the EGR with a plate from TPIS - not sure if that matters or not. Do you guys have any suggestions? Thanks!
Chris
Old Aug 29, 2006 | 05:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
could be lean or maybe the cat is shot
Old Aug 30, 2006 | 02:21 PM
Car: 1989 Trans Am
Engine: l98
Hey thanks for the reply - but I'm running a straight pipe in place of the cat
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
