Chevy heads 3/8 or 7/16 rocker studs
Old Aug 30, 2006 | 04:00 PM
Destructive099's Avatar
Car: Dark Blue 1987 Chevy Iroc-Z Camaro
Engine: 5.7 350
Axle/Gears: 3:42
Got me a set of AFR195cc heads and a nice cam with about 550 max lift ive got people telling me to get 3/8 base and 7/16 rocker nut thread size for extra security and strenght do i need this will this help alot ?
Old Aug 30, 2006 | 04:04 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If I'm reading that correctly, you want to use a 7/16" rocker nut on a 3/8" stud?
Old Aug 30, 2006 | 04:09 PM
Engine: 5.7 350
Axle/Gears: 3:42
ehh what i mean is the base of the stud that threads into the head is 3/8 the top of the stud where the roller rocker gets put is 7/16 thus requiring 7/16 roller rockers instead of the normal 3/8 , another question I had is does this change anything going to 7/16 for instance will I need longer push rods different shims ect ??
Old Aug 30, 2006 | 04:18 PM
I see. Unless you're doing a monster build up,(like a mechanical roller cam with aggressive valve lift and duration, with some really heavy springs to match.) you don't really need the bigger top stud. the 3/8" will work just fine. It's already gained a lot of strength due to the thread-in seats. If you go that, you may as well have the heads machined for 7/16" base thread as well. You're only as strong as your weakest point.
Old Aug 30, 2006 | 04:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
IIRC, the lower thread (that goes into the head) is the same for either 3/8 or 7/16 studs. Its just the top of the stud, where the rocker goes, that is larger. 7/16 would be stronger than 3/8, but what are the specs of the cam and valve springs you are running? I know a few guys using cams much bigger than .550 with only 3/8 studs and no problems.
Old Aug 30, 2006 | 05:00 PM
Engine: 5.7 350
Axle/Gears: 3:42
k last thing im unclear on is if I get the 7/16 studs do I have to change anything else besides getting the 7/16 roller rockers ?
Old Aug 30, 2006 | 06:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My old 383 had 7/16" studs. The cam was around .550 lift. Spinning the engine to 7000 rpm, I wanted to make sure the rocker stud wasn't flexing. I also used 3/8" pushrods and guideplates.
You need to buy SBC rockers for the 7/16" stud. BBC rockers, which use 7/16" studs, are the wrong length.
For most applications, a 3/8" stud will do fine. 3/8" rockers are easier to find.
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
