pushrod length.
Old Aug 31, 2006 | 12:29 PM
devilfish's Avatar
pushrod length.
First sorry for my english.
Engine is a chevy -91 355, canfield 197cc heads and a gm lt4 hotcam with *525 lift.
Im about to check the pushrod length due to new heads and cam.
But i whas to hurry and mounted the heads and intake before i know that i whas supposed to use a solid lifter instead of the hyd lifter when checking the pushrod length.
Well whats done is done..
I read on the internet about 2 diffrent methods I can find to do this.
1:Finding Proper Pushrod Length - Circle Track Magazine
This i tried but as i got hyd lifter installed i cant get a consistent reslut on my rockers, but if i take a avrage it seem pretty much in the vavle tip center.
2: Or this. Mount the rocker when the lifter is at the base of the cam, markt the vavletip with a pen. Then viggle the rocker left to right and se that its center or a tiny bit against the intake side off the valve tip . This i did and can confirm its center.
I also tried this device.
Buy Performance Car Parts at Summit Racing!
But that jsut made it even more confused. Accoring to that i got 0.078" to long pushrods. BUT if i use my adjs pushrod and take away 0.078" the other 2 tests fails. So i dunno?
Any tips are whery welcomed
Old Aug 31, 2006 | 12:30 PM
devilfish's Avatar
the proform test "device"..
the 0.078"
http://www.vetteforum.org/attachment...2&d=1156947446
Old Aug 31, 2006 | 12:31 PM
devilfish's Avatar
The wear mark, i used alutejp on the vavletip also used a pen to mark it up, same result..
http://www.vetteforum.org/attachment...9&d=1157044764
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
mfp189
Sep 27, 2015 09:25 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
