L98 Freshen Up
Old Sep 3, 2006 | 08:25 AM
Ljolivia's Avatar
L98 Freshen Up
I got a stock L-98 5.7L '89 Iroc.
I am in the process of upgrading with some bolt-on stuff...
LT-4 Hotcam Kit with new springs & 1.6 roller rockers
1-3/4" SLP Headers
Hi-Flow Cat
3" Borla Cat-back system
Edelbrock Hi-Flow TPI base & Runners
5 angle valve job with some mild port clean-up...
maybe:
having the plenum ported
adjustable fuel pressure regulator
chip
bigger throttle body...
Has anybody used this combination...??...What kind of horsepower should I expect...???
Also. I saw some chatter on these boards about the "Pressed in" rocker retainer studs..?? Not planning on racing this when I get er done, but want to take care of a possible problem while I got the engine apart....
Thanks,
Larry
Old Sep 3, 2006 | 09:11 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Screw in studs only :-)
Pull some studs out otherwise and I will laugh and say I told u so.
Its not that much to do and saves lots of aggravation.
The LT$ hotcam TPI has been beat to death here do some searching.
WIth some tuning, they run well, I had one once.
later
Jeremy
Old Sep 3, 2006 | 06:14 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Agreed, use screw-in rocker studs. They are cheap insurance because it really doesn't take much to pull out the pressed in studs. Screw-in studs won't pull out. If you stay with pressed studs, and happen to pull one out, its a nightmare to fix without pulling the head off. Take the heads off, take them to a machine shop, and have them machined for screw-in studs, buy a set of ARP studs, and call it a day.
Old Sep 4, 2006 | 12:26 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You'd be better off buying a new set of heads with a cam that big. Our stock heads suck, and while you will have more power, it wont run as well as an engine with that cam should.
I had to make my own custom chips for my LT4 hot cam install. Just buying a Hypertech or whatever generic chip wont cut it.
Old Sep 6, 2006 | 04:40 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
chip...
I got my PROM from PCMforLess.com- excellent choice, best bang for the buck so far! Definitely port that plenum. I spent 5 hours on mine as I"d never done any porting before. You can send yours in and have a basic port done for less than a hundred bucks I think, or there's this guy Mike that does corvette TPI MEGA-porting- His stuff will give the approximate same flow and power increase as the Holly stealth ram.
I was just in the process of deciding to refresh my 88 L98 block but have decided, due to the awful heads we have, to just go ahead and do a ZZ4 short block build.
Nitro
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
Tarizza
Sep 24, 2015 12:57 PM
