mini starter
Old Sep 9, 2006 | 01:57 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
mini starter
so my starter **** the bed and i went out and got a new mini starter (fits 153 and 168), let me say its a lot lighter and easyer to put in when laying on the ground, i didnt know if i hade the 153 or 168 tooth flex plate so i have on idea what need to be done to the mounting plate of the starter befor i install it, anyone have any advice?
Old Sep 9, 2006 | 03:02 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
just bolt it in then pull the pinion out to see how well it mates to the ring gear...adjust from there....on a side note i didnt think there was a starter that fit both tooth count ring gear....tao
Old Sep 9, 2006 | 03:30 PM
Alot of the mini-starters have both bolt patterns; which makes it work with either size of ring gear, but IF AND ONLY IF your block has the late-model bolt pattern. Which about any block from 80-up or so, will have.
Just use the set of bolt holes that works. I don't think you'll have too much trouble figuring out what to do, once you start doing it and you see what the parts look like.
Old Sep 9, 2006 | 06:51 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
all of our cars came W/ the 153 tooth flywheel, , depending on your individual car you may have to "clock" the starter on it's mounting plate, and for the 153 tooth flywheel you will use the mounting holes that move the starter closer to the block
Old Sep 9, 2006 | 08:16 PM
high c's Avatar
Car: 86 iroc
thanks man
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
