water mixing with the oil
Old Sep 11, 2006 | 09:46 PM
racman15's Avatar
ok so i have an 87 camaro v6. when i start it the rpms are all over the place, today i drained the oil and it looked like the mocha you get in the starbucks bottle so thats no good, i checked to see if the plugs were rusted due to water damage but nothing. i have no white smoke or anything, so i dont know what the problem is!!!
if anyone can help me it would be very much appreciated
Richie
Old Sep 11, 2006 | 09:48 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
You need to replace your head gaskets
Old Sep 12, 2006 | 12:53 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
it could also be the intake gaskets. I think . I know if the intake is leaking then the coolant will be brownie batter, not sure how the oil would look though. There could be a crack on the intake gasket underneath one of the coolant passages causing coolant to leak into the valley. I would ASSUME that if it were a head gasket then it would smoke somewhat through the exhaust. But you know what they say when you assume...
Old Sep 12, 2006 | 07:42 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
So you have water in your oil. Is the car running low on coolent? Do you have to add anti freeze routinly? If you're not using water, then the stuff in your oil isn't comming from there. Also, if you have water in you oil, you should also have oil in your water. See any?
Old Sep 14, 2006 | 10:25 AM
racman15's Avatar
the resevoir is always empty, but no oil in my coolant, or in my radiator. my radiator is full, so idk what the problem is???
Richie
Old Sep 14, 2006 | 06:54 PM
Coach Hawk's Avatar
maybe your resivoir has a hole in it? If the radiator is always full, you don't have a leak somewhere.
Hotrodboba400
Dec 10, 2019 07:07 PM
69GTOby
Apr 18, 2016 02:34 PM
customblackbird
Oct 1, 2015 04:30 PM
TheExaminer
Sep 28, 2015 02:28 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
