center bolt valve covers
Old Sep 14, 2006 | 07:10 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Does any one know if these (normal) wide body rockers will fit under these Proform valve covers? the are .45" taller than stock and do not have the sheet metal braces like the factory steel covers do.
Old Sep 14, 2006 | 07:55 PM
sean86sc's Avatar
Car: 86 camaro sport coupe
Engine: 355
no, you need the narrow body rockers to fit under center bolts. From my buddies experiance even with those the proforms didn't fit well. Grinding was required
Old Sep 14, 2006 | 10:07 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
i have a question:
if i have a stock engine, (reproduction GMPP 350) with prety mcuh stock components
WILL those awesome looking centerbolt valvecovers fit on my motor??
waht do you mean "grinding" was required?
grinding of what?
they look damn good
poelase let me know
Old Sep 14, 2006 | 10:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yes, you can use those centerbolt valve covers.
grinding is required to use the wider than stock rockers, if you don't have those rockers, no grinding required.
Old Sep 14, 2006 | 11:36 PM
F-BIRD'88's Avatar
Where, is "grinding" required? What part of the rocker contacts the inside of the valve cover?
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
