Car is running bad, no power...stumble under throttle.
Old Sep 15, 2006 | 08:27 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Started all the sudden one day about 2 months ago. Stumbled real bad under throttle, no power. I scanned the car, and saw no O2 reading. replaced the O2 and the entire harness. Doesnt throw a code anymore for the O2. BUT it still has the same stumbling problem. It gets worse when its warm. This lead me to think it was the CTS, so I replaced it, but that didnt solve it. I havent had a chance to scan the car again, or to check the fuel pressure, but what else could it be?
Old Sep 16, 2006 | 09:06 AM
Vader's Avatar
Any error codes? It's eaiser to scan the ECM than it is to drain the cooling system and change the CTS.
Old Sep 16, 2006 | 11:46 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
tap on the mafs and see if the idle gets crazy again
91transamGTA's Avatar
Car: 91 Trans Am GTA
Transmission: 5 speed
hey
i have the same problem with my car and i tryed everything i checked the codes and im only gettin a code 12
Old Sep 16, 2006 | 11:52 AM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
whats the mafs? me and 91transamgta been trying to get his car going since a week or more,just the same ol spudder,and miss.its like theres a senser not working or a vacume not working
Old Sep 16, 2006 | 07:07 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
Sounds like lack of fuel pressure to me. Its not to hard to check. If thats not it, I would guess vacuum leak or bad MAF.
Old Sep 16, 2006 | 07:54 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
ya it was the map senser 4 sure.put another one on er now she runs mint.
Old Sep 17, 2006 | 09:54 AM
Car: 89 formula 350
I have a speed density conversion on my car, so no MAF sensor. I scanned the ecm yesterday and it appears that everything is working as it should. I have a Fuel pressure gauge im going to snake under my hood and drive around a little so I can see what the pressure is doing. Maybe I cant put off that racetronix pump anymore
Old Sep 17, 2006 | 10:32 AM
Vader's Avatar
That's a good idea if there are no error codes.
Old Sep 17, 2006 | 11:04 AM
Car: 89 formula 350
is it possible for the pump to work ok when cold, but act up when hot? I guess its possible, but Ive never seen it before. I always thought when a pump was bad, it just stopped :shrug:
Old Sep 17, 2006 | 11:32 AM
joe350's Avatar
Car: 91 Z28
Fuel pumps, like all electric motors, work worse when hot. Usually the fuel keeps them cool, however. Thats why electric fuel pumps are installed in the tank. Also, you don't need to drive it around with the pump attached. Just test while in the driveway. If the pressure drops when you increase throttle, then you found your problem.
Old Sep 17, 2006 | 11:51 AM
Car: 89 formula 350
ok so I drove around and the fuel pressure stays pegged at 43 at WOT. I also swapped in a good used MAP, which didnt help. I tried an extra 730 ecm, no dice. Its gotta be ignition related. I have a brand new MSD coil on there now, and a recent module but I guess those are next to try?
Old Sep 17, 2006 | 12:25 PM
Car: 89 formula 350
All injectors just ohmed out at 13 ohms
Old Sep 17, 2006 | 05:37 PM
Car: 89 formula 350
failing ignition module?
Old Sep 17, 2006 | 09:30 PM
Car: 89 formula 350
hmm, guy I know has put in his vote for a bad pickup coil....maybe I should just pop in a new distributor?
86IROC112
Aug 17, 2015 02:00 PM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
3rdgenparts
Aug 6, 2015 09:03 AM
